Unit works fine until it is turned off. Cooling fan operates and soon it shows pf and the latch motor starts to click. Never fails during use. Did order new door latch as the existing one is bent and hits the door. Ordered control also but wondering if anybody has experienced this problem. Can hit cancel to clear the code. I do not suspect the breaker or wiring because it does not fail under the load of the elements.
  • Replies 1
  • RegUS_PatOff
  • NCARepair
Tech Sheet - 8304173.pdf
link PM'd
