The drain pump can be heard to activate but there is no water coming out of drain hose. The line is clear. Is it possible the pump impeller broke from lack of use/lack of water, upon start up after having been stored for a long time?
Is there a tech sheet for this?
16026394.pdf
link fixed
Edited by RegUS_PatOff
Thank you for linking the file. I was unable to download it. Could you link it once more please.
fixed link ..
having problems lately with MediaFire
Ok. THanks for the tech sheet! I don't have a service manual for this model. I'm going to need to remove the drain motor to see what's broken. It looks as though the dishwasher has to be removed from its cavity to get to the pump? A service manual may help; will you please link one if you available. Thank you.
Drain Pump
Removal
1. Disconnect power to the machine.
2. Remove Support and Toe Panel.
3. Disconnect lead wire from Pump Assembly.
4. Disconnect drain hose from Pump Assembly.
5. Remove Torx™ screw through bushing in Pump Mounting Plate.
6. Rotate Pump Assembly to unlock from Tub.
http://appliantology...tainless-steel/
