Hi all, I wanted to run this by some of you experts since my knowledge of microwaves is limited.  I have a double oven microwave that runs fine but no heat.  I removed the microwave unit from the oven and brought to shop for diagnose.  So far I have checked all fuses and the capacitor and they check fine.
Tested diode and it drops to 6V on a 9volt battery and reads mV when reversed.
I tested the magnetron terminals and they both had resistance of less than 1 ohm, also checked from terminal to mag body and showed infinity.  It looks as though the magnetron is ok.  Is this a foolproof test?
I didn't really know how to test the transformer and I can't power the unit on without it installed in the double oven.
Any thoughts out there?
Thanks,
Nick
  • Replies 6
  • Blue Frog
  • Cactus Bob
  • jumptrout
The ohms test is no way to test a magntron , all your testing is the filament , and most bad magntrons have good filaments
i always thought the ohms test was stupid , but i guess it's the only way to test the thing
my rule of thumb : check everything else , if it's all good and you still have no heat , replace the magntron . i have been right 100% of the time
I am lucky , i have a bunch of used "test" magntrons , to just switch it out and see what happens
just so you know , magntrons are all wired the same inside , as long as you can mount the mag even if it's just 2 screws , you can use it to test for heat .  just use your head and be sure to mount it with a good seal and don't leave an incorrect one on for more that a few mins while testing
and the the original problem was no heat ?
(not a blown Fuse) ?
Thanks for the reply!
Yes original problem was no heat, and I the ceramic and thermal fuses check out ok.
Why can't you make a test cord to power the M/W?
No model number here, but a test cord to the primary side of x-fmr to by-pass door switches, relays, etc...  and if your diode and cap check out OK, narrows it down to the mag if no heat.
