Waring wct 805b toaster 1/2 working
Go to solution Solved by Cactus Bob,
Catlin repair
I have a waring commercial toaster that has 4 slots controlled by 2 timers and boards. One side works fine, the other side only one of the elements gets hot. When it does it glows very bright red, much hotter than normal. I have tried replacing the element and the board the controls that side of the toaster neither of which helped.
Any suggestions?
  • Catlin repair
  • Cactus Bob
  • Solution
without knowing how your toaster is wired
I would guess you have 2 elements that are wired in series  . each element is rated for 60 volts (2 times 60 =120 volts)
the element that is out is not only out but is shorted , to itself or the case of the toaster
giving the other brite element to much voltage
so you have wires touching each other or a heating element that is shorted somewhere
note: this info is all based on regular toasters and toaster ovens , that i have been bringing home from the age of 12 , i know i was a very strange kid
Catlin repair
thanks Cactus Bob, I will try replacing the element that its paired with
Catlin repair
Worked like a charm, Cactus Bob. Thanks a bunch
