Repair Manuals
winenotwhine
What's the status on access to repair manuals.? I've followed links to X drive but I'm not getting to any manuals.
  • Replies 19
Last I checked, it's working fine. Did you follow the instructions carefully in the email and set up your xdrive account, including your name? If so, then you should be all set. Just go to http://xdrive.com and log in, should see the manuals in your file listing.
Not sure which email you're referring to--can you resend?
Resent. Check your inbox and your junk mail folder. If you're still not getting it, lower your spam filter settings and I'll re-send again. Or PM me a different email address to try.
OK---I found your initial email and registered with user name John@ridgewine.com.  I get into X drive fine but theres nothing in my files.
Have you made certain that you added your name in your Xdrive account, as instructed in the introductory email? If you don't do this, you show up in my share list as ::private:: Since I don't know who ::private:: is, I delete this. I've done this twice since you subscribed. Maybe it's you?
I entered my name, John olney, though my user name is my email. When I go to "My Profile", it does not say anything about private.
Maybe the problem is that I subscribed using my wife's email eko@hwines.com but then registered using my email, john@ridgewine.com ?
I sent the Xdrive access link to your ridgewine email.
So, when you log into Xdrive and you go to My Account and then My Profile, you see your name in the "Account Name" field?
Yes.
Account name: John Olney
Login Email address: john@ridgewine.com
My password is XXXXXX. Maybe you should login to see if I'm missing something?
My dear friend, will you please send the Samurai a PM with your password??  Thanks so much.....
No sure what that is, but I couldn't log in with that information.
I sent you another access link. If you use it and see the files but I see someone in my share list as ::private::, I'll know you don't have your account set up properly.
Ok--thanks.
Back to the washer, one thing has been bugging me. I moved this dishwasher about two miles in a pick-up. Before the move it worked great. During the move, the electric clip on the yellow lead to the capacitor got bent pretty severely.
I re-bent it, and its associated prong on the capacitor, back in shape--connection seems tight. When I replaced the bad heat element, the long cycle delay (20 minutes) that happened at 60 minutes improved. Now the hangup is at 46 minutes. Could a bad connection at the capacitor relate to the extended cycle?
The wiring diagram specs 23.5 mF at the capacitor. I don't recognize the units so can't check.
What's the model number on this dishwasher?
GU1500XTLS0
(Serial FM4609062)
This is the Point Voyager design from Whirlpool-- there's no capacitor on this machine. There are, however, turbidity and temperature sensors that, if malfunctioning, can cause the problem you're having. Post a picture of the part you're talking about.
In the Kitchen Appliance Forum look at the last post for subject Whirlpool Dishwasher Dec 19th to katherinemay written by Pegi.
She givews a link to the spec sheet for the GU1500 that shows a capacitor mounted to the side of the wash motor. That's the part I'm referring to that was bent and bumped.
You are correctum! That's what I get for working from memory and not reviewing the schematic.
This page will show you how to test the capacitor. It's unlikely that's the problem, however, because if it were bad, the washer motor wouldn't run. And I'm assuming the wash motor does run, right?
Yes--the wash motor definitely runs--that's actually the problem. It sticks specifically when it reaches 60 minutes and 46 minutes left in the normal cycle. It runs for about 6 minutes at 60 ( as in it doesn't tick down to 59,58,57...) and then 15 minutes at 46 minutes showing on the panel.
And guess what? It completes the wash just over 20 minutes late. It takes about 95 minutes for it to do a wash that the display says should be done in 73 minutes. I've run dirty dishes, clean dishes and no dishes--exact same results.
Yanno, this sounds an awful lot like water heating delay. Are you running the hot water in the sink 'till it's hot before running the dishwasher? If not, that initial charge of water will be cold and the dishwasher will run while it's heating the water to 140F, resulting in a run-time delay. If the dishwasher is working fine otherwise, then that's probably what's happening.
[align=left]This is copied from your tech sheet.[/align]
[align=left]LONG CYCLES[/align]
[align=left]AND/OR STUCK[/align]
[align=left]IN CERTAIN PART[/align]
[align=left]OF CYCLE[/align]
[align=left]As part of normal[/align]
[align=left]operation, the[/align]
[align=left]dishwasher pauses 2 or[/align]
[align=left]3 times during the[/align]
[align=left]cycle for thermal holds[/align]
[align=left]and advances once[/align]
[align=left]temperature is met.[/align]
[align=left]Customer Instruct – explain thermal holds[/align]
[align=left]and that the Water Heating (Pause) and/or[/align]
[align=left]Sensing LED’s indicate when they are[/align]
[align=left]occurring.[/align]
[align=left]Low inlet water[/align]
[align=left]temperature.[/align]
[align=left]Confirm temperature at sink (recommend[/align]
[align=left](49° C/120° F). Instruct customer to run[/align]
[align=left]water at sink before running dishwasher.[/align]
[align=left]Dishwasher hooked up[/align]
[align=left]to cold water line.[/align]
[align=left]Confirm and correct installation if[/align]
[align=left]necessary.[/align]
[align=left]Problem with[/align]
[align=left]temperature control[/align]
[align=left]devices or circuit:[/align]
[align=left]■ Loose connection(s).[/align]
[align=left]■ Thermistor problem.[/align]
[align=left]■ Problem with thermistor[/align]
[align=left]input on control.[/align]
[align=left]Check all components and connections in[/align]
[align=left]the water heating “sensing” circuit:[/align]
[align=left]■ Check resistance of all connections in thermistor[/align]
[align=left]circuit[/align]
[align=left]■ Check resistance of thermistor.[/align]
[align=left]■ Check control’s ability to read thermistor in[/align]
[align=left]Diagnostics.[/align]
[align=left]Heater problem (not[/align]
[align=left]heating water or stuck[/align]
[align=left]on in dry):[/align]
[align=left]■ Open connection or[/align]
[align=left]component in heater[/align]
[align=left]circuit.[/align]
[align=left]■ Open in heater.[/align]
[align=left]■ Faulty heater drive circuit[/align]
[align=left]on control.[/align]
[align=left]the water heating “heater” circuit or heat[/align]
[align=left]dry circuit:[/align]
[align=left]■ Check resistance of all connections and[/align]
[align=left]components between heater and control.[/align]
[align=left]■ Check resistance of heater.[/align]
[align=left]■ Check operation of heater in Diagnostics cycle[/align]
[align=left](confirm that it comes on and goes off).[/align]
Thanks, Pegi! :dude:
