May I have a manual & tech sheet for Frigidaire dryer GLEQ2152ES0  Has Error code E68.   Thank you,  Patricio
tech sheets
134509400efsa.pdf
E68 Key (button) Struck Fault
One of the keys (buttons) is stuck / closed (active).
Enter function test mode and perform key (button) test to determine which button is at fault.
Carefully free the button and perform the test again.
If button is free but the key struck code still exists, replace electronic control.
click on picture
http://www.repairclinic.com/referral.asp?R=154&N=1154933'>User-Control-and-Display-Board-134523200
