      6
GE GG40T06AVG01 pilot lights but larger burner never starts.
Michael Sandifer
GE GG40T06AVG01 pilot lights but larger burner never starts. Wondering where to start on this one. The heater has been sitting not used for the last 7 months. I can light the pilot but the heater never kicks on. Is there an easy fix. Also this unit has SMART SHIELD.  Any suggestions would be great.
  • Replies 1
  • Michael Sandifer
  • jumptrout
Instructions
  • 1
    Avoid blocking the base of the GE water heater if the sensors do not seem to be functioning but the water heater has power. Keep the path of the sensor clean. The sensor is located under the sediment trap and the thermostatic gas valve. Make sure that the catch pan is out of the path of the flammable vapor sensor.
  • 2
    Wait 30 minutes or more if the SmartShield sensor system has activated before trying to reactivate power to the machine if the water heater shuts down automatically or the error light flashes seven times with a three-second pause. The wait time will allow the vapors to pass out of the system and from the cement around the water heater. Check for possible gasoline, paints, stains, solvents, bleach or other chemicals, cleaners or substances in the area that might trip the sensors, and remove them as needed. Turn the “On/Off” switch, which is located on the gas control valve, to turn the system back on.
  • Sponsored Links
  • 3
    Flush out the GE water heater system if the sensors are operating erratically. Lift up on the temperature pressure release valve handle, and let the water drain into a large bucket or open drain. Once several gallons have drained, close the temperature pressure valve and allow several hours for the tank to refill.
  • 4
    Contact GE to have the sensor replaced if errors continue when there are no chemicals or other vapors near the water heater, or the error flashes repeatedly.
Read more: How to Troubleshoot a GE SmartShield Sensor System | eHow.com http://www.ehow.com/how_12055874_troubleshoot-ge-smartshield-sensor-system.html#ixzz2Ge4NKEWt
