Click here to take the quiz.
Manual requested for this washer.  Appointment friday morning.  Complaint is machine runs erratically.  Stops mid cycle,  does not spin out clothes.  Recon I am going to spin some time with it.  Not much to go on.  Will check drain trap & electrical connections,  any other advice will be heeded judicially.   Patricio
servied unit today,  was not there 10 minutes.   started a normal cycle without clothes  or detergent.  Washer filled with very soapy water. while filling took top off.  There was so much clear shipping tape wrapped around everything.  Could hear the ticking, grinding of the bearing.  Put unit in drain cycle then did the Samari test for tub bearing.  So much sloppy play, don't know how the unit stayed together,...oh yea, shipping tape :rolleyes:    Needless to say I condemed it. :yucky:
Edited by Samurai Appliance Repair Man
Added video for checking drum bearings.
