Display says EF error code. Equivalent to kenmore sxs 253.44383402. Want to be able to check power control board and fan.
Edited by NCARepair
  • Replies 5
  • NCARepair
    4
Thank you sir. This ref just quits with EF and ff light off about once a week. Unplug and plug in and works again. Has the panasonic fan motor. Just going to quote fan motor and main board.
That's what I would do on an intermittent problem where you can't actually catch it in the act.  Not much other choice.  Don't want to just change out the muthaboard because if the fan motor is really the problem, it'll take out the new muthaboard.  Best gut the beast and be done with it.
Main PCB ==> http://www.repairclinic.com/PartDetail/Main-Control-Board/241511102/1056492?modelNumber=PHSC39EJSS0
Main-Control-Board-241511102-00998370.jp
Evaporator fan ==> http://www.repairclinic.com/PartDetail/Evaporator-Fan-Motor/241509402/1196443?modelNumber=PHSC39EJSS0
Evaporator-Fan-Motor-241509402-00689572.
Edited by Samurai Appliance Repair Man
Thanks,that is what i am going to do.
