Frigidaire Dishwasher PLD3465REC0 service manual request
Sunlight Appliance
Mod: pld3465rec0
Is this tech manual available?
Client has this dishwasher that is intermittently unresponsive at the touchpad and frequently shows "Er" and "PF."
Thank you
There's a service bulletin out on this problem:
FRIGIDAIRE DISHWASHER
Dishwasher Stops After Power Supply Interruption
Models: GLD3450RD, GLD3451RD, GSB6400ND, PLD3460RD, PLD3465RE,FDB2810LD.
Problem: Display showing a code of "EE".
Cause:There has been a momentary interruption in the power supply to the dishwasher.This causes the control to stop all of its operations and functions.
Solution: Shut off the power to the dishwasher for 5 seconds, then turn it back on. This will clear the control and a "PF" code should appear in the display. To check the control, select one of the wash cycles then press the start pad, the cycle shouldstart normally. If the "EE" code reappears, technicians are advised to replace the control. Very rarely will the control need replacing.
