trying to access food chopper ,  but cant disassemble ...... ??? must consult with gurus :thanks:
Also worth mentioning customer says," runs and drains at same time" ........
        ??Baffled??
  • vunger1
  • RegUS_PatOff
... customer says," runs and drains at same time" ........
it's the same Motor .. it can't do both at the same time ..
unless the D/W Drain Tube is installed wrong and it's siphoning
Sorry, i meant , fills and drains at the same time.
is there a way to access the cntl. bd. to run diagnostics ?
