    • 11 October 2025 02:00 PM Until 03:00 PM
      When: Saturday, October 11 @10:00 AM Eastern Time.
How can i get the drain valve unstuck as i do not want to break it off. Trust me i have broken one off the old water heater before. The hot water heater is just not putting out that much hot water anymore. It is an electric water heater.
model number - FG1H4040T3N0V
serial - 0444103206
product- 0730266
Posted (edited)
Here is the value. I would hate to break it off.  But it is not turning.
or is there a better way to drain it
post-53870-0-20387800-1364738525_thumb.j
Edited by mmoore5553
no , there is not any other way to drain the water safely
but
draining the rust out of the bottom of the heater will in no way help the heater produce more hot water
draining only removes loose rust from the bottom of the tank so the tank lasts longer
you have an element or thermostat problem
OR  a broken / corroded Cold Water Input Dip Tube /Anode,
but that's another discussion :)
His is a gas water heater. So does that change anything
look at that , it is gas , i never really looked at the photo before
yes draining the rust may restore the hot water
did you try turning off the flame for a day or so to let the tank cool down , this may release the plastic and let you turn the valve
there is another way , but it requires a little work, some fittings and air compressor
remove the in and output of the water heater from the house plumbing
use fittings to connect a garden hose to the input (cold) of the water heater
carefully pump a little air at a time into the hot water output
the water should leave out the garden hose
it should be light enough to take outside and remove that old plastic drain valve and replace it with a good metal one
it's work, but sometimes real work is the only way to get something done
Do they have heating elements?
I would change the valve without draining, turn it off, allow to cool, shut off supply, get new valve ready! Get a towel or two, remove old valve and quickly install new one, I've done elements and gas valves this way
... remove old valve and quickly install new one
although, it may break upon / before removal ..
be prepared..
if in basement, may not be so bad ..
