Do you have the technical service guide and/or any bulletins for a GE washer model# GTWN4250dows? Thanks.
  • beckrob
Thank you for the service bulletin and schematic. What I'm really looking for are technical specs for the precise fill logic and the times for each cycle. For example, how many minutes the water value will remain open after the low water pressure switch is opened and how many gallons of water each setting provides.
I'm also trying to find out more about the jumper switch settings on the control board. How many washer models use the same control board but a different jumper switch.
Did GE release a technical service guide for this washer or for profile washers with a hydro-wave wash system?
