    • 15 March 2025 02:00 PM Until 03:00 PM
      When: Saturday, March 15 @10:00 AM Eastern Time.
May I obtain a manual for this washer.   Revised Customer complaint is that they laid washer on its side  to clean out drain.  Now Sometimes the washer works OK For several loads, then hiccups & does not finish cycle.  Then unit works fine in subsequent loads & hiccups again.  Last load the bleach cycle did not work.
Edited by Patricio
  • RegUS_PatOff
  • Patricio
FAFW3574KW0
tech sheets
137063900.pdf
Edited by RegUS_PatOff
... FAFW3574JW0
forgot to ask...
maybe
FAFW3574KW0 ?
forgot to ask...
maybe
FAFW3574KW0 ?
Maybe,  Made call today, Tech sheet was with unit & still is.  Part # 137063900B  (0911)
Customer said drain pump was cleaned last November.  1st thing I checked.
Put in Diagnostic mode, E11 error code, Not complete fill.  Put unit thru diagnostic steps,  2nd step cold water did not fill first time,  but did  every other time.  Started checking wire connections, all clean except the main harness connection where 2 pins had the turquoise corrosion.  Cleaned with welding tip cleaner & electrical connection aerosol cleaner.   Unit running fine, I left.   Good South Texas coast salt air.
