r4fun2000
Overload keeps tripping.  I replaced the overload, relay and capacitor - still trips. Compressor checks out fine.  I'm thinking it might be something related to the motherboard inputs or outputs.  I've read a little on other models where the ice dispenser is the culprit - which is found by disconnecting that connection to the board.
I need the manual for guidance here.   Thanks.
Well, it's not the muthaboard.  The compressor has become a hard starter.  This can be difficult to prove analytically without some fancy-pants equipment like a megger.  But based on the symptoms you describe in this unit, the compressor is on its way to the great beer cooler in the sky.
Can't find a manual for this one but here's the tech sheet:  http://appliantology.org/files/file/789-ge-25-cu-ft-sxs-refrigerator-mini-manual-gsl25/
... Overload keeps tripping.
... I replaced the overload, relay and capacitor
correct part numbers ?
WR07X10131
click on picture
WR62X79
click on picture
