KitchenAid SxS Mod# KSRA25FKSS00 tech sheet needed
Need a service manual or at least the tech sheet (LIT2216445) for:
Kitchen-Aid SxS Refrig
Mod# KSRA25FKSS00
Ser# SL4053047
I need to know how to put it into a manual defrost, (to see if it will go into a defrost), with the user interface controls.
It has a defrost problem, (heater and defrost t-stat both OK), evaporator plugged with ice and refrig temp setting seems to change by itself randomly.  I'm pretty sure I have a main control board problem causing the defrost problem and the refrig temp setting changing as I here relays clicking on/off when it should be running.
  • Budget Appliance Repair
  • RegUS_PatOff
Thanks, that is just what I needed.
Now for some questions over in the kitchen.........
