Hi REG! is there a service manual for this? I need to know the resistances of the ntc in order to rule out the relay stays at 404 to 434 ohms while running with the relay jumped out. Any tech manual would be greatly appreciated. Thanks as always!!
  • Replies 6
  • telefunkenu47
  • RegUS_PatOff
  • btenpin
  • Spannerwrench
are you sure of that model number ?
yes. model no is correct. I couldnt find anything either. Ill call Marvel this morning.
These units are often seen as Vking labels, mfr by Marvel.  Pretty simple to work on as long as can unit to start may have to use test cord at compressor.  Good frost pattern you need "service kit" includes thermister, SSAC control and potentiometer.  Insufficent frost sealed systen. The kit is  Basicly everything electronic.  File is too large to attach you may need service kit #42244531 , these units generally fail in one of two ways.  The unit will either be dead no compressor, or run continuouse and blow up all diet pop, and beer.
I will try to send file as PM
... These units are often seen as Vking labels, mfr by Marvel.
... service kit # 42244531
THERMISTOR (42244531) Viking part number PW240050
Viking Models that Have Used This Part:
DFUW152
DFWC141
DFWC151
DUWC141
DUWC151
DUWC152
VUWC141
VUWC151
VUWC152
Domo...much obliged!!!! thnx for the info.
The control that was listed almost always is the problems with these, we carry these as standard truck stock. They can be used on almost all of the Marvel built units. Just make sure you adjust the slides on the switch properly, here's the service manual.
https://www.dropbox.com/s/wznsyvdoxm7bkpt/3BARM%2C%206BARM%20MicroSentry%20Service%20Manual.pdf
Here's how to set the switches per model.
https://www.dropbox.com/s/9wvae6tj7o8rbyx/SSAC%20Field%20Replacement%20Installation%20Instructions.pdf
