abbinoxious Posted June 13, 2013 Posted June 13, 2013 Ice maker makes ice randomly. Need troubleshooting guide & repair manual please. Only 98 volts at the end of wiring harness that leads to ice maker.Thank you
DurhamAppliance Posted June 13, 2013 Posted June 13, 2013 I'm not so certain voltage is your problem...how are freezer temps...and I think this manual will serve your purpose better.....http://appliantology.org/files/file/266-whirlpool-optical-in-door-ice-maker-job-aid/ as well as this video 1
RegUS_PatOff Posted June 13, 2013 Posted June 13, 2013 ... Only 98 volts at the end of wiring harness that leads to ice maker.Is that voltage measurement taken with the IceMaker connected ?(should be) http://appliantology.org/files/file/959-kenmore-fridge-10652762100/
