Service manual request: Kitchenaid Ref. KSSC48QTS02 Parts List
isappliance
I need a wire harness for this unit and can not find it on the diagram. I was wondering if anyone had a service manual for this unit that I can pull the part number from. Any help is appreciated.
  • DurhamAppliance
  • isappliance
  • Captain Dunsel
  • Ironhead Dave
which wire harness do you need?
  • 7 years later...
Ironhead Dave
I know this is 7 years old, and not sure if it will be seen, but i also need a wiring harness that is not listed on the available parts. It is the harness that connects to the auger motor. Thanks for any and all help. kssc48qts02 Model number
Next time just ask for what you need without the old thread. Here you can use this. Sorry thought you were asking for the tech sheet! Any way the tech sheet and wiring diagram and ice maker is the same as your Model.If you need the Exact Parts List.Go Here!
Go to servicematters Limited Access. Click on it. Put your model number in where it says part number and then click on Parts list. https://servicematters.com/en_US
Edited by Captain Dunsel
