Reg,
Send the Jenn-Air range SCE340B wiring diagram, please.
Thanks in advance,
Tyrus
  • Replies 8
  • RedToryTy
    5
  • RegUS_PatOff
  • Spannerwrench
maybe
SCE4340B
or
SCE4340B-C
Sorry; SCE4340B
I can find the parts manuals,
but I can't find the wiring diagram for either model ..
what problem are are you having ?
Won't go into clean. Ohm the four micro switches; ALL have resistance.
how much resistance ?
They may be bad (dirty / greasy)
  • 2 weeks later...
First no resistance, then spikes to .03 downward.
  • 4 weeks later...
Thanks for your efforts, Spannerwrench. Unfortunately, the manual contains control board-operated ranges; this product uses a capillary temperature control and switches.
Replaced all four micro switches: with both selector and temperature control set to "CLEAN," I can latch and unlatch the cleaning latch. When turning down the temperature control to 400, the door latch locks. No cleaning, however; because the oven successfully bakes, I draw the conclusion something's wrong at the selector and/or the thermostat.
Any relevant experience? Critical comments? Snide remarks?
Thanks in advance,
Tyrus
