Need parts manual for ordering Small  and Large oven thermostat.
Large oven T-Stat P/N PB010036
Small oven T-Stat P/N PB010035
Thank you guys. now i have to figure how to take a part the bullnose part to install the thermostats
  • 2 weeks later...
If you have not already figured it out, here is my late reply. You do not need to remove the entire bullnose on this range. The control panel can be removed to access the thermostats by removing 4 screws at each corner then 2 of the lower screws under the 2nd and 3rd burner knobs. I may be wrong on the exact location of these screws but with the drip tray removed you can feel where they are. At this point the control panel is free, you can pull it out and access the thermostats. Be careful putting it back in when finished because some of the wires tend to get in the way of the burner tabs, getting pinched, shorting, you know the rest of that story. Good luck.
  • 4 years later...
