Manual request please.
ww2750 Jenn Air double wall oven.
Thank you
  • Replies 4
  • jumptrout
  • RegUS_PatOff
  • tpoindexter
Door is locked and can not get it open.
Removed control panel to manually activate latch.
Still can not h
get latch to release.
HELP.
Edited by jumptrout
I couldn't find a manual for this model but did run across this if it helps:
If there is an unlock button try holding it in for 30 seconds, then, see if it'll open.
or
Try turning the breaker off to the unit for 60 seconds to see if it will reset.
If not, then try to set the self clean, wait 60 seconds and cancel it to see if that will reset the door latch assembly. If nothing resets the door lock, then you just need to manually open the door and replace the door latch assembly.
It's not easy to manually unlock the door.
You'll need to use a coat hanger and pull the latch assembly from RIGHT to LEFT by slipping it down between the door and the oven frame at the top. Force the latch over to the left and open the door, then you can remove the panel in front of the door latch.
Edited by tpoindexter
all I could find
or
Already did all this.
