Window a/c heat and cool 240 volt.  Can turn unit on at selector switch and fans and compressor start.  When unit is turned off for 5 minutes and turned back on, nothing happens.  Operation control board is separate from main control board.  Found a slider switch on main board marked Con - Cyc.  Closest thing on the schematic shows fan cycle switch.  Is this an energy saver switch and if it is, why is it hidden on the main control board in the control compartment?
Never mind.  It is an energy saver switch and I'm an idiot.  There is a small pass through hole in the control cover stamped Cont - Cycle.  No mention in the tech sheet so I assume it's covered in the use and care guide.  :wacko:
