The paperwork that came with the fridge said to push the fridge switch 5x in 6 secs. Which I did quite a few times with no result. I wanted to make sure that was right for this model. If it is, is there a way to test the board to make sure it is bad before I change it. The reason I question the defrost sequense is that it has a digital display which I can't find in my paperwork.
Thank you for all your help, it's been really appreciated.
David
  • Replies 1
  • RegUS_PatOff
  • dcoyusa
... The paperwork that came with the fridge said to push the fridge switch 5x in 6 secs.
... is there a way to test the board to make sure it is bad before I change it.
yes
tech sheet 240389622
check the voltage at the Genesis Controller P1 pin 7
http://appliantology.org/files/file/1286-frigidaire-refrigerator-glhs67eep/
Frigidaire Refrigerator
GLHS67EEPB0
GLHS67EEPQ0
GLHS67EEPW0
5995433272 parts
240389622 tech
