I am asking for a repair manual for a whirlpool dryer mod. # wed9200sq1. It keeps blowing high limit thermostats intermittently. Do you have any nifty ideas why? I mean besides a short some where that we can not find.
  • Replies 1
  • RegUS_PatOff
  • abbinoxious
could be a Heating Element partially shorted to chassis / ground
could be a Venting problem
What are the Vent temperatures ?
Check the Vent air temperature at the back of the Dryer using a probe-type thermometer.
click on picture $ 2.99 sometimes on sale
Dryer Vent:
Vent should be rigid metal.
NO plastic
NO PVC
NO screws
Foil Duct Tape is OK.
Check / clean the Dryer Vent
Whirlpool Dryer
WED9200SQ1
Repair Part List - W10194580
Tech Sheet - W10198666
was:
Tech Sheet - W10177459A
available after upload approval by the Samurai
