    • 12 April 2025 02:00 PM Until 03:00 PM
      When: Saturday, April 12 @10:00 AM Eastern Time.
I am asking for a repair manual for a whirlpool dryer mod. # wed9200sq1. It keeps blowing high limit thermostats intermittently. Do you have any nifty ideas why? I mean besides a short some where that we can not find.
  • Replies 1
  • abbinoxious
could be a Heating Element partially shorted to chassis / ground
could be a Venting problem
What are the Vent temperatures ?
With an empty load, Timed Dry, High Heat, the vent temperature should cycle somewhere between 135F and 160F
Check the Vent air temperature at the back of the Dryer using a probe-type thermometer.
If you have a Harbor Freight Store near you,
click on picture $ 2.99 sometimes on sale
Dryer Vent:
Vent should be rigid metal.
Short lengths of flexible metal may be OK, if not crimped when moving the Dryer into place.
NO plastic
NO PVC
NO screws
Foil Duct Tape is OK.
Check / clean the Dryer Vent
Disconnect the Dryer Vent and check for good air-flow there and where it exits the house.
Whirlpool Dryer
WED9200SQ1
Repair Part List - W10194580
Tech Sheet - W10198666
was:
Tech Sheet - W10177459A
available after upload approval by the Samurai
