Need service manual for Samsung RFG297AAPN - RFG297ABPN/XAA
Samsung french door bottom freezer
Mod# RFG297AAPN
Ser# C77943CZ100283L
Bom# RFG297ABPN/XAA - Note: ABPN different then model# AAPN
Need service manual please, Thanks.
http://appliantology.org/files/file/869-samsung-refrigerator-and-washer-rapid-repair-resolution-guide/
Multiple models of refrigerators and washers.
The following refrigerators plus many WF models.
RB195ABBP/XAA / RB195ABPN/XAA / RB195ABWP/XAA / RB195ACBP/XAA / RB195ACPN/XAA / RB195ACWP/XAA / RB217ABBP/XAA / RB217ABPN/XAA / RB217ABRS/XAA / RB217ABWP/XAA / RF197ACBP/XAA / RF197ACPN/XAA / RF197ACRS/XAA / RF197ACWP/XAA / RF217ABBP/XAA / RF217ABPN/XAA / RF217ABRS/XAA / RF217ABWP/XAA / RF217ACBP/XAA / RF217ACPN/XAA / RF217ACRS/XAA / RF217ACWP/XAA / RF263AEBP/XAA / RF263AEPN/XAA / RF263AERS/XAA / RF263AEWP/XAA / RF266AEBP/XAA / RF266AEPN/XAA / RF266AERS/XAA / RF266AEWP/XAA / RF266AZBP/XAA / RF266AZPN/XAA / RF266AZRS/XAA / RF266AZWP/XAA / RF267AEBP/XAA / RF267AEPN/XAA / RF267AERS/XAA / RF267AEWP/XAA / RF267AZBP/XAA / RF267AZPN/XAA / RF267AZRS/XAA / RF267AZWP/XAA / RF268ABBP/XAA / RF268ABPN/XAA / RF268ABRS/XAA / RF268ABWP/XAA / RF268ACBP/XAA / RF268ACPN/XAA / RF268ACRS/XAA / RF268ACWP/XAA / RF26XAEBP/XAA / RF26XAEPN/XAA / RF26XAERS/XAA / RF26XAEWP/XAA / RF4287HABP/XAA / RF4287HAPN/XAA / RF4287HARS/XAA / RF4287HAWP/XAA / RFG237AABP/XAA / RFG237AAPN/XAA / RFG237AARS/XAA / RFG237AAWP/XAA / RFG238AABP/XAA / RFG238AAPN/XAA / RFG238AARS/XAA / RFG238AAWP/XAA / RFG293HABP/XAA / RFG293HAPN/XAA / RFG293HARS/XAA / RFG293HAWP/XAA / RFG295ABBP/XAA / RFG295ABPN/XAA / RFG295ABRS/XAA / RFG295ABWP/XAA / RFG297AABP/XAA / RFG297AAPN/XAA / RFG297AARS/XAA / RFG297AAWP/XAA / RFG297ABBP/XAA / RFG297ABPN/XAA / RFG297ABRS/XAA / RFG297ABWP/XAA / RFG298AABP/XAA / RFG298AAPN/XAA / RFG298AARS/XAA / RFG298AAWP/XAA / RS2530BBP/XAA / RS2530BSH/XAA / RS2530BWP/XAA / RS261MDBP/XAA / RS261MDPN/XAA / RS261MDRS/XAA / RS261MDWP/XAA / RS263TDBP/XAA / RS263TDPN/XAA / RS263TDRS/XAA / RS263TDWP/XAA / RS265TDBP/XAA / RS265TDPN/XAA / RS265TDRS/XAA / RS265TDWP/XAA / RS267TDBP/XAA / RS267TDPN/XAA / RS267TDRS/XAA / RS267TDWP/XAA / RS275ACBP/XAA / RS275ACPN/XAA / RS275ACRS/XAA / RS275ACWP/XAA / RS277ACBP/XAA / RS277ACPN/XAA / RS277ACRS/XAA / RS277ACWP/XAA / RSG257AABP/XAA / RSG257AAPN/XAA / RSG257AARS/XAA / RSG257AAWP/XAA
416 pages
http://appliantology.org/files/file/699-samsung-refrigerator-fast-track-manuals-bundle-3-of-5/
Samsung Refrigerator Fast Track Manuals Bundle - 3 of 5
RFG293HA Fast Track.pdf
RFG295AB Fast track R2.pdf
RFG297AA Fast track R1.pdf
RFG297AB Fast track R2.pdf
RFG297HD R2 Fast Track.pdf
RFG298AA Fast track R1.pdf
RFG298HD Fast Track.pdf
RF4287HA Updated Fast Track R4.pdf
RF4289HA Fast Track.pdf
RFG29PHD R2 Fast Track.pdf
RFG237AA Fast track R1.pdf
RFG238AA Fast track R2.pdf
RFG238AABP Fast Track.pdf
RFG238AAPN Fast Track.pdf
Already found and have all those, the rapid resolution guides gave me another part# I didn't have from the parts break down for the sensor, (appears in both AAPN and ABPN builds both refrig and freezer temp and defrost sensors can all use DA32-10109W).
I was hoping to find a detailed service manual that covers the RFG297* that shows more details about diagnostics and what the motherboard does when it finds one of the sensors open/shorted, (if it goes into some default mode?).
Thanks RegUS
Samsung fridges ALWAYS performs sensor checks at start up. This is also the reason you must record any error codes before unplugging fridge as it erases previous codes.
Also, from samsung training manual:
"Defrost Sensor–The sensor shuts off heater At 50in Freezer, 63in Fridge –If the sensor is bad it may shut off the defrost circuit in a few minutes or not start, causing ice build-up, or it could lock up in defrost mode and become a total no cool . Note: A defective sensor may check OK at room temperature, test at operating temperature. "
btw, for clarity any open/shorted sensors on a Samsung can cause a fridge lock up, not just the defrost sensors.
Thank you so very much, that's the one I needed!!!!
thanks ...
so many different Samsung model numbers / manuals
(and no part # for this manual)
Amazon Best Sellers Rank: # 2,051,491 in Books
  • 9 years later...
Thank you.
