WE have a whirlpool range. If you turn on the oven it will light but if you turn it off then try to turn it back on it will not light. However you can smell a faint gas smell. We replaced the igniter. It just didnt seem to be sparking enough. It is still doing the same thing. I need a tech sheet to trouble shoot this problem. Thank you.
  • RegUS_PatOff
  • abbinoxious
... FG361LVQ1
maybe
WFG361LVQ1 ?
Has this Oven worked OK up till now at this location ?
Does the Broil work OK ?
not much in the tech sheets
http://appliantology.org/files/file/1372-whirlpool-range-wfg361lv/
Whirlpool Range
WFG361LVQ1
WFG361LVB1
WFG361LVT1
WFG361LVS1
WFG361LVD1
Repair Part List - W10245708
Tech Sheet - W10198615
after upload approval by the Samurai
Un sure if the broiler works. Will check it out today. The stove is new to this rental.so I am not sure as to if it worked before. Will have to find that out as well. Thank you for the files.
check the polarity of the Wall Outlet
Line, Neutral, Ground
must be in the right locations
