tpoindexter Posted November 7, 2013 Posted November 7, 2013 If any one has this manual I would appreciate it. Thanks Tracy
RegUS_PatOff Posted November 8, 2013 Posted November 8, 2013 http://appliantology.org/files/file/660-samsung-dryer-timer-countdown-problem-service-bulletin/Samsung Dryer Timer Countdown Problem Service BulletinModels: DV218AEB/XAA, DV218AEW/XAA,DV218AGB/XAA,DV218AGW/XAASymptom: In sensor dry cycle, the timer counts down to 6 minutes then adds 1:06 on the display.Solution: Replace the Main PCB Assembly http://appliantology.org/files/file/663-samsung-dryer-fast-track-manual-dv203-dv337/Samsung Dryer Fast Track Manual DV203 - DV337Models: DV203*** DV206*** DV218*** DV306*** DV317*** DV328*** DV3C6***DV209*** DV219*** DV316*** DV326*** DV337***Revision 4 1
