Need a tech sheet, with schematic for Whirlpool washer mod.# WFW9050XW00. Have to do some wiring harness repair and there is no tech packet in this washer?
  • Replies 5
  • dablacks
    4
  • RegUS_PatOff
Thanks Reg!
Sorry that wiring diagram is not correct for WFW9050XW00. Any suggestions?
These two models do appear to use the same tech sheet, but they do not share the same ccu or pressure switch and the wiring is different.
... These two models do appear to use the same tech sheet,
... but they do not share the same ccu or pressure switch
... and the wiring is different.
hhmm .... another mistake by Whirlpool
I did some searching,
will try a little more
