KSSC48FKS00 KitchenAid built-in 230v Refrigerator Manual Request
Sunlight Appliance
Reg!
I got the manual for KSSC48QMS02 from Durham and we think it may be compatible for the issue at hand:
Power Outage occurred in client's region. When power came back the refrigerator compressor would not start. Self diagnostic mode by the tech sheet showed compressor failure. I checked input voltage to inverter at 120v and output voltage to compressor at 65v. So I diagnosed a bad inverter since it was not putting out 230v.
Then the Samurai and Durham reminded me that these compressors are variable (due to ridiculous government regulations that wreck havoc while attempting to save the planet) and do not operate at 230v full time. I need to go back and check the DCv communication circuit between the motherboard and inverter board. Will the manual I downloaded tell me the correct connection points to test with my voltmeter?
KSSC48QMS02 (year 2003) Downloaded
KSSC48FKS00 (year 2001) Don't have this manual but is the one above compatible?
Link to other forum: http://appliantology.org/topic/45867-local-power-outage-took-out-refrigerator-inverter-transformer/
  • Replies 4
  • Sunlight Appliance
  • RegUS_PatOff
  • DurhamAppliance
just pull up the diagrams on both and check to see if boards and interface are the same. If so, the models should be sufficiently compatible. Hopefully, however, Bro Reg will find your exact manual.
Edited by DurhamAppliance
Sunlight Appliance
Okay. Just trying to have it diagnosed correctly, once and for all, when I get there. There is a tech sheet in the unit. That is the only diagram for it I have access to.
http://appliantology.org/files/file/604-kitchenaid-2001-k-model-built-in-side-by-side-refrigerator-with-variable-capacity-compressor-service-manual/
KAR-11
2001 K MODEL
BUILT-IN SIDE-BY-SIDE
REFRIGERATOR WITH VARIABLE
CAPACITY COMPRESSOR
MODELS:
KSSC36FKB00
KSSC36FKS00
KSSC36QKS00
KSSC42FKB00
KSSC42FKS00
KSSC42QKS00
KSSC48FKB00
KSSC48FKS00
KSSC48QKS00
KSSP36QKS00
KSSP42QKS00
KSSP48QKS00
KSSS36FKB00
KSSS36FKT00
KSSS36FKW00
KSSS36FKX00
KSSS36QKB00
KSSS36QKT00
KSSS36QKW00
KSSS36QKX00
KSSS42FKB00
KSSS42FKT00
KSSS42FKW00
KSSS42FKX00
KSSS42QKB00
KSSS42QKT00
KSSS42QKW00
KSSS42QKX00
KSSS48FKB00
KSSS48FKT00
KSSS48FKW00
KSSS48FKX00
KSSS48QKB00
KSSS48QKT00
KSSS48QKW00
KSSS48QKX00
JOB AID 4317326A
Edited by RegUS_PatOff
Sunlight Appliance
Thank you!
