kenmore 110.92581200
temujin
washer fills, starts to agitate, then stops after approx 30 seconds. after a minute or 2 we hear a click and then it starts again
same thing happens on all cycles, including spin. Slight burning smell. tried new motor - no change
no obstructions in pump. coupler appears ok. no leaks.
  • Replies 1
In the general case, this problem will be either a motor or a timer. Since you've already replaced the motor, that leaves the timer:
http://www.repairclinic.com/referral.asp?R=154&N=1173
Before ordering the timer, be sure to check the integrity of the wires at the motor wire harness connector. Tug on each wire in the connector and look for blue corrosion.
