Suction is o.k. heads don't work, it has voltage where power goes into the hose at the cannister but no power after the on/off switch on handle, the 3/way switch on handle, first position turns the suction
on o.k. but no light, second position doesn't turn on the head, i have flexed the hose to check for shorts but appears none. maybe the pcb?
  • Replies 1
  • Scottthewolf
  • OPELGENT
Could be the PCB, there is a fuse assembly in there as well, and there is a separate PCB just for the light as well.  Instead of ordering parts and finding that you didn't need the part, it may be just as cost effective to take your vacuum cleaner to your local Sears parts & repair center for a diagnosis/repair.
http://commercial.searspartsdirect.com/partsdirect/retrieveModelAction.pd?modelNumber=116.27814701&pathTaken=partSearch
Edited by Scottthewolf
