GE range JSP42S0K4SS ......Trying to calibrate, any help is greatly appreciated! Thanks
  • Replies 1
  • RegUS_PatOff
  • The Rag Man
Temperature adjustment / calibration ?
To adjust the Thermostat,
Press the BAKE and BROIL HI/LO pads at the same time for 3 seconds until the display shows SF.
Press the BAKE pad.
A two-digit number shows in the display.
Press BAKE again to alternate between increasing and decreasing the oven temperature.
The oven temperature can be adjusted up to (+) 35ºF hotter or (-) 35ºF cooler.
Press the number pads the same way you read them.
For example, to change the oven temperature 15ºF, press 1 and 5.
When you have made the adjustment, press the START pad to go back to the time of day display.
