William Daniel Carney
i need the tech sheet/service manual for a whirlpool gold french door bottom slide out freezer. Model Number GX2FHDXVQ00.
If I missed it searching for it I'm sorry.
standard bottom mount jazz board fridge.... this tech sheet should work for you http://appliantology.org/files/file/985-maytag-aff2534few-refrigerator-jazz-board-tech-sheet/
if you have a defrost problem or temp problem it's a 95 percent chance you need to replace the jazz board. If you are having a drainage problem then you need to replace the duck bill grommet. http://appliantology.org/files/file/1480-whirlpool-service-pointer-ice-build-up-on-bottom-of-freezer-defrost-water-does-not-drain-duck-bill-check-valve-plugged/
see videos http://appliantology.org/topic/41567-how-to-put-the-jazz-control-board-into-service-mode-in-maytag-jenn-air-amana-refrigerators/?hl=jazz
http://appliantology.org/topic/42721-fixing-a-warm-amana-bottom-mount-refrigerator-with-the-jazz-adc-control-board-pt-1-diagnosis/?hl=jazz
http://appliantology.org/topic/42725-fixing-a-warm-amana-bottom-mount-refrigerator-pt-2-replacing-the-jazz-board/?hl=jazz
and possibly http://appliantology.org/topic/42822-how-to-remove-the-top-rack-inside-the-freezer-compartment-of-a-whirlpool-bottom-mount-refrigerator/ for top rack removal.
Edited by DurhamAppliance
Thanks for your help.
