Honeywell temp thinger on wall
Do these things fail ever? I ask because today, the bedrooms on our top floor are super warm. The temp reads 75! No one has touched the thermostat and when I try to make the heater kick on by turning the wheel, it doesn't click. However I can hear the boiler running. Come to think of it, it might be running constantly!oh my oil!!!!! Any thoughts? Thanks for helping!!!!
would need picture or model number of Thermostat
Some use quiet "mercury tilt" switches
Here. Are some photos
Just a sec, trying to upload. The # is T87F 1800 2 EU.
The temp is going down, somehow.
That's it. Now I was able to get the temp to drop, and haven't heard the heater kick on by itself. But tonight, I will see if I can get it to work again. Maybe it was a fluke? This suckas about 50 yrs old I think. Maybe it's time for a new one?
A replacement base is available. Specify gas or electric heat when ordering. Johnstone supply or grainger should be able to hook you up.
That photo isn't exactly what we have. There is no cooling ability, so the back of the dial doesn't exist on my unit. I can't seem to upload the photo either!
Oil heat, too.
Now its working fine, but I did figure out how to upload the photos.
must have been a fluke, or one of my kids isn't telling the truth!
thanks for your help!
post-35737-0-84106000-1389915166_thumb.j
post-35737-0-80632100-1389915186_thumb.j
post-35737-0-67997200-1389915195_thumb.j
"Do these things fail ever? I ask because today, the bedrooms on our top floor are super warm. The temp reads 75! No one has touched the thermostat"
--Answer:Yes they can get out of calibration or stuck. did you clean the dust buildup off it to take the picture? you may have fixed it by doing that.
--Answer: mercury bulb thermostats never click. if they do , you better run :rocketwhore: ......
--Answer: It is unlikely that your  round thermostat directly controls your boiler. it probably turns on a fan, or enables a valve to put hot water to radiators or something similar.   your boiler maintains a constant temperature so hot water is available whenever you need it.
  • Like 2
wow, just a little dust could throw it outta whack?
don't let my husband know that...
its obvious who has failed in her wifery duties! (sheesh!)
thanks for the tips!
Thermostat dusting is headed under"Husband Duties".
