Want any illustrated manuals you have, found a tech sheet for KSRB25QGss01.
Kitchen aid is it made by Frigidaire, will look for answer but if you can confirm thanks.
The relay for compressor has been removed, need to test compressor to see if it will run, has run cap.
  • curjones
The model number must be ksr8 (not B) 25fhss04.  Ive tried to search sit using KSR8 * and got nothing.  Im still trying to find.
Thanks Samurai,  Got to look for notes on run cap, and start cap, para, and series.  They guted the relay and pct is not there need to see if compressor will run.  I've used 3 and ones on other models but think they have start cap, got some studying and research to do.
