Maytag coin op washer MAT12PDLAW
Code D3 - Water temp problem, Water valve??
Maybe. Parts breakdown shows this as a thermistor/valve combo.
However, it might be telling the truth and the water supply could be jacked up.  Checking the basic basics: did you make sure your hot is hot and your cold is cold?  Trust me, it really sucks to scooch out a heavy coin op, wriggle yourself in back, change out the valve and discover it was the water supply all along.
Hots hot, colds cold. Hot water was super hot, do they have to turn hot water heater down?
  • 3 weeks later...
Replaced water valve, bam story over, repair good!!
  • Like 3
