I need an Electrolux dishwasher service manual for model EIDW6405HT0
Or at least error codes or diagnostics.  Customers dishwasher has dF code.  No idea how to proceed and I can't seem to locate this model on the Frigidaire/Electrolux tech site.
DF= Drying fan error.  Drying fan in at the top right corner of the tub, You need to pull the dishwasher out from under the counter to access it.  These fans are a troublespot as well as the wiring harness that goes to it,  it tends to get tangled in the right hand door hinge and eventually cut or frayed.
  • Like 2
Thanks guys.
I didn't see this in the downloads, so here it is.
Service Manual 5995516648
It was there. The correct pub number is 5995516548. If you searched for 5995516648, you would not have found it. But you would have found it if you searched by partial model number with wildcard.
Changed link to the manual in the Downloads section.
That was probably it.  My eyes aren't as good as they used to be, and two fat left thumbs on an iPhone key pad can screw with you.
I'm right there with you, mah bruvah!
