File Name: Whirlpool Washer Motor Spring Kit Instruction Sheet
File Submitter: RegUS_PatOff
File Submitted: 24 Feb 2014
File Category: Appliance Repair Manual Pot Luck Supper
Whirlpool Washer
Motor Spring Kit 285901
Instructions Sheet 285902.pdf
This kit contains three (3) springs.
Your application will require only one (1) depending on the color of the label on your motor.
If the label on your motor has green stripes, use the green-striped spring as the replacement part.
If the label on your motor has blue stripes, use the blue-srtiped spring as the replacement part.
In all other applications, use the plain spring to complete your repair.
The springs are matched to the performance of the motor;
therefore, it is necessary to match the correct spring to the color of the motor label.
Click here to download this file
  • Replies 0
  • RegUS_PatOff
