Dear Master,
Could I please get a service manual for VIKING Model#DDBB363RSS.Iam having a defrost problem with htis unit.
Thank you,
SMANERA
Supersedes:TR-0055C-SP     TR–0055B–SP
Model(s): VCBB360, VCBB362, DDBB362, DTBB362,
DFBB362, VCBB363, DDBB363, DTBB363,
DFBB363
For use on units manufactured prior to March 7, 2007.
Subject: Improper draining due to ice accumulation at drain tube inlet.
Solution: A secondary drain trough (kit number 016774-000) has been created to prevent freezing
of the primary drain. This drainage system is designed to confine defrost water and channel it to the
drain pan.
A heater probe (part number 025532-000) was added that attaches to the center section of the defrost
heater and runs directly into the drain tube to provide added heat in the drain tube during the
defrost cycle.
A small tube of silicon (part number 041917-000) has been added to provide a seal around the neck
of the drain tube to further enhance the secondary drain trough kit.
Date: JULY 2013
No: TR-0055D-SP
http://appliantology.org/files/file/1636-viking-refrigerator-technical-bulletin-improper-draining-due-to-ice-accumulation-at-drain-tube-inlet/
TR-0055D-SP
Edited by Samurai Appliance Repair Man
Added file to Downloads section.
