Washer fills but won't agitate or drain/spin. In spin mode the Timer sends 38 VAC to the lid switch. I need to confirm that my issue is with the Timer and not the Pressure Switch. I'd greatly appreciate the Service Manual for this Unit.
  • Cityboysrus
The Service Manual or Wiring Diagram would've made this quicker, but after following the gray wire from the Lid Switch to the Motor Switch I noticed a burn mark on the Female connector that connects to the motor switch. I cleaned the male terminal and removed all the wires from the quick connect and straight wired the motor wires. Another satisfied customer in the Land of Appliances. :rocker:
I would greatly appreciate the wiring diagram for my records. This was a good one!!!
