    • 15 February 2025 03:00 PM Until 04:00 PM
      Returning guest presenter Aaron Wilson is back for another exciting discussion. This time, we'll be talking about...
      The Science of CYA: How to Keep the Customer Safe, Document Your Work, and Not Get Sued
      We take on a lot of liability as appliance repair techs, and that can get us into sticky situations whether we've done anything wrong or not. Aaron will be teaching us all about how to navigate this side of the trade.
      We'll start by going over a tragic, real-world case study where a sloppy installation had lethal results, analyzing exactly how the installer's negligence caused this. From there, our scope will expand to what kind of safety precautions we should implement in our own work, both for the customer's sake and for our own.
      But even if you do everything perfectly, there's still the famous "technician witch hunt." Well, we'll also talk about how to deal with that by thoroughly documenting your work and putting yourself beyond legal reproach.
      A little about our guest, Aaron Wilson:
      Aaron has been in the appliance repair trade for about 15 years, starting out by doing installations before moving on to bigger and better things. He worked for C&W Services as a Sub-Zero authorized servicer for a time and thereafter joined Mr. Appliance of Highland Park in the Dallas area, where he worked for years as the lead technician and field service manager. These days, he's making sure that all the appliances of everyone's favorite fried chicken place are in tip-top shape as the Quality and Performance Consultant for the southwest branch of Chick-fil-A. In addition, he has taught many classes on refrigeration repair and advanced diagnostics, during which time he also developed training material for the soft skills side of things, which he is delighted to share with you. On top of all that he's a certified graduate of the Master Samurai Tech Academy, so he knows his stuff!
      When: Saturday, February 15 @10:00 AM Eastern Time.
the Surface Burner Elements on the unit, have a solid flat surface, I need to replace one so i was hoping the Manual will tell me if the one shown here, is encased inside the one I see on the machine.
it appears the Drip pans are different to.
  • Budget Appliance Repair
  • brm
If you don't know the history behind were those elements came from it might be difficult to find replacements! The range is a 2002 model it appears from the parts list.
The only parts listed in the manufactures parts list is exactly what you see in the parts break down picture, (Standard coil elements).
If you elements look like the solid European elements those would be aftermarket units that were available a long time ago, I don't know if they are still available or not, (I think I recall seeing them in one of the mail order junk catalogs recently).
I have an old parts catalog from 2001 that list the replacement "Cast Iron European Style Elements", they were made by QBProducts which I believe is still making aftermarket products, (I don't know if these part# are good anymore or not - Universal 6" with stainless trim ring 5007908 and Universal 8" with stainless trim ring 5007907.  They also had ones specifically for GE models and also with black porcelain trim rings and two special ones with only the black trim rings, one 6" and one 8" that were made to go over the position in the rear if the oven vented out the center of the element).
I did a quick check on AppliancePartsPros and RepairClinic, they both have the parts above listed as available but not in stock, ($75-$85 each and no pictures).  Looks like they are made by ERP, (Exact Replacement Parts), now.
A picture of what you have might help someone identify exactly what you have.
