Request manual for this oven.  I haven't figured out how to search the data base for it. Sorry for the bother if I could have found it an easier way.
Doc
  • electro_doc
  • tpoindexter
Thanks, it looks like there is no diagnostic test, is that correct.  Also says if F3 is showing as the error code then you have a bad temp sensor.  I changed the sensor and still get the F3 and checked the old one and it is fine.  Ended up at the control board and found a bad trace.  The board was not getting the message.  The board is no longer available so I soddered in a jumper to bypass the bad trace.  I'm going to try that tomorrow.  I'll let you know.
Thanks for the manual
Doc
