Service Manual GE Fridge PFS22SISBSS
Lionelsson
Lionelsson
Looking for SM for GE PFS22SISBSS Profile French door Freezer/Refrigerator.
Edited by DurhamAppliance
ADDED, MAKE AND MODEL NUMBER TO TITLE
Information on this model is easily found in the download section using truncated searching. Please watch this video
Then search the Download section for "PSS22I*" and you will find the manual.
Then I'm certain after watching the video you took some initiative, modified my typo, complied with forum rules (see http://appliantology.org/topic/47178-please-search-the-downloads-section-before-posting-a-service-manual-request/) and searched for "pFs22i*", right?
What was the search term you used?
Thanks for trying! I'm sureyou'll get the hang of it and when you do, you'll find a wealth of info throughout this site..
Searching "pfs22si*" (don't include the quotation marks).
You should see two entries in the dl section
http://appliantology.org/files/file/1525-ge-bottom-mount-refrigerators-service-guide/
And
http://appliantology.org/files/file/507-ge-refrigerator-minimanual-31-51651/
Lionelsson
PFS22SISBSS is the appliace I am concerned about.  I have tried PFS by itself and other combinations.  When I search forums I find these post but nothing else.  Are you seeing something different?
Waaay different!  For one thing, I'm not searching the forums, I'm searching just the Downloads section as I demonstrated in the video.  Did you watch it?  It's very short-- watch it again.
Check the box next to the box you typed your search string. If it says "this topic" that means you are searching only within this topic, the topic you created. Click on "this topic" and change it to "downloads."
And, don't forget to put the SHIFT 8 - STAR at the end for wildcard search.   If you are leaving that off it is looking for exactly what you type as a complete word which it will usually never find.
