arrow 1 Posted May 21, 2014 Posted May 21, 2014 I need to remove the top of this unit to replace element. I have looked at the gy396 that is in manual downloads. But this gy398 is totally different. Has anyone had to work on this unit or have the manual? Much appreciated!
DurhamAppliance Posted May 26, 2014 Posted May 26, 2014 (edited) Arrow, it would really be helpful if you posted the manufacturer and type of appliance. Someone may have some experience with this but many of us do not keep model numbers in memory and have no idea what you are talking about.. Could be a dryer, an oven etc. There may even be someone who has access to every whirlpool oven manual in existence but doesn't know this is a whirlpool, let alone an oven. So instead of going through the extra step of looking up your number, that one tech who could have helped you would simply bypass your post. It's even better if you posted that info along with the model number in the title itself. ThanksBtw also ask your disassembly question in the kitchen forum. Someone may know the answer and can help you without a manual. Posting the full info in the title will help there as well. Edited May 26, 2014 by DurhamAppliance
