ducktoller
NEED A SERVICE MANUAL FOR THIS DRYER UNLESS IT IS SIMILAR TO ANOTHER ONE THAT i CAN DOWNLOAD.
Pretty sure the one that comes up for Download search WED94H* is different than the one needed for WED94HEXWO - different publication number and the wiring diagram is different too.
The correct Tech Sheet is:  http://appliantology.org/files/file/1737-wed94hexwo-tech-sheet-w10306459a/  (Link will be good once approved by somebody.)
  • Like 2
Thanks Strathy, file approved. However Duck, it's still incumbent on you to learn and apply search techniques for the future.
ducktoller
Well actually I did do all those techniques wildcards and such and never found what I was looking for that is the only reason I posted .  I did find everything else I needed and thank your for posting the correct one I needed as well.
Great Duck! Many people do not take that initiative. However, sometimes it is helpful if you let us know the only manual you found in the download section that seems similar is, in fact, not compatible. Otherwise, we would have to pull diagrams etc to see if the manual is compatible. We do that quite often and it is a real pita. Especially for people who are volunteering their valuable time to assist. So a little "heads-up" can go a long way. It also benefits you as the response is faster and more accurate.
Edited by DurhamAppliance
ducktoller
ok got it thanks.
