Janes Appliance Posted June 8, 2014 Posted June 8, 2014 need a service manual for GE ref model# GSS20GEWRBB
DurhamAppliance Posted June 8, 2014 Posted June 8, 2014 (edited) did you search the Download section using wildcard searches?.. ie search for: GSS20*make sure to watch this short screencast regarding search techniques Edited June 8, 2014 by DurhamAppliance
Janes Appliance Posted June 9, 2014 Author Posted June 9, 2014 yes I did use wild card search and searched for GSS20*....but it did not appear to be for the ref I was working on I will look at it again and double check.....thanks
DurhamAppliance Posted June 9, 2014 Posted June 9, 2014 (edited) ok, if you kept making your wildcard search string longer you would find this tech sheet http://appliantology.org/files/file/710-ge-refrigerator-minimanual-31-51716/You can also get the full manual under your original search string by downloading the GSS encoder sxs manual. Understand that your model is nothing but a standard GE GSS encoder (knobs used on the interface in the ff section) but they the intetface is at the dispenser controls. If you examine the tech sheet you will see the dispenser interface with the notation "when applicable." It is applicable to your model, unfortunately meaning there is no on board diagnostics unless you have the diagnostic kit. Thanks for attempting to search... this one was a bit tricky unless you know GE's but if you have my GE Fridge Survival Kit, you would have easily figured out how to work on this fridge even if you could not find a manual...http://appliantology.org/blog/1/entry-730-ge-refrigerator-repair-survival-kit/ Edited June 9, 2014 by DurhamAppliance
