Roper 2496X0 (Zero at end) need service manual or answer to question
Old (Sept.1986) Roper Slide-in Down-draft electric range
Mod# 2496X0A   -  "A" is color code and not used in look up
Ser# 6S65585
Need a service manual, but for one this old, probably not going to find that - but would be nice.
I need to know if anyone knows if access to the surface control/Inf Switches is possible without pulling this unit out/having to disconnect the downdraft blower to move it.
It looks like from the parts diagrams the panel just above the oven door/below ERC and all Inf switches is removed for direct access to all of the control area.
  • Budget Appliance Repair
Come on guys, 45 views and no help????????
Most of those clicks were probably me un utter disbelief that you're working on a range this old!
If I coulda found something for you, I woulda posted it.  Even ServiceMatters doesn't have anything on this old dawg.  Only other thing I found for it was an installation manual which covered nothing you need.
OK, thanks any way.
Was pretty sure I wasn't going to get a service manual but was hoping someone here has worked on one of these and at least had an to the question of access to the surface control switches.
I have to go out on it in about 1/2 hour and will find out when I'm there.
Thanks again guys...........
