Need service manual/tech sheet.
  • jambatt
  • Scottthewolf
This is a Samsung built washer. There are no service manuals for this unit unless you are a service technician for Sears.  What problems are you having with the machine?
Unit will only partially fill with water. Customer says that clothes are only damp when it runs the rest of the cycle. Does unit have a water level sensor or is it a timed fill cycle??  As usual it is located in a closet with the dryer sitting on top. Don't want to have to to move the dryer but once if you know what I mean.
